عبدالرحمن زياد
عبدالرحمن زياد
Apr 26
Hi, for a 2011 Suzuki Swift 1.5 automatic that's run 110,000 km, here's what you might want to consider for maintenance to avoid getting ripped off: 1. **Oil Change**: Check and replace the engine oil and oil filter. 2. **Transmission Fluid**: Inspect and possibly replace the transmission fluid. 3. **Brake System**: Check the brake pads and brake fluid. 4. **Coolant**: Inspect the coolant level and top up or replace if necessary. 5. **Air Filter**: Check the air filter and replace if dirty. 6. **Tires**: Check tire pressure and tread wear. 7. **Battery**: Test the battery to ensure it's in good condition. 8. **Belts and Hoses**: Inspect for any wear and tear. It's always a good idea to consult your vehicle's manual or a trusted mechanic for specific recommendations.
سلمان خليفة
سلمان خليفة2024-04-28 23:52
How much did you get it for? I just got a 2011 model with 110,000 km for 25,500. I feel like I overpaid. The maintenance cost me quite a bit since there were many parts that needed replacement.
عمر حليم
عمر حليم2024-04-27 10:04
I also want to get one. How much did you get it for? How's the fuel consumption? I've heard the automatic Swift has high fuel consumption?
عبد العزيز مرشد
عبد العزيز مرشد2024-04-27 08:42
How much did you get it for? I want to get one too.
سلمان بشر
سلمان بشر2024-04-27 00:05
Transmission fluid, engine oil, oil filter, air conditioning filter, coolant, brake pads—Swift is quite durable. Just use some good fully synthetic oil.
Maintenance guide for the 2007 Opel Astra: 1. **Regular Oil Changes**: Ensure you change the engine oil and oil filter every 5,000 to 7,500 miles to keep the engine running smoothly. 2. **Brake System Check**: Inspect brake pads and discs regularly, approximately every 10,000 miles, and replace them as needed to ensure safety. 3. **Tire Maintenance**: Check tire pressure monthly and rotate tires every 6,000 to 8,000 miles to ensure even wear and prolong tire life. 4. **Air Filter Replacement**: Replace the air filter every 15,000 to 30,000 miles to maintain optimal engine performance. 5. **Coolant Level**: Check and top off the coolant level regularly to prevent the engine from overheating. 6. **Battery Check**: Ensure the battery terminals are clean and the battery is functioning properly, especially before winter. 7. **Transmission Fluid**: Inspect and, if necessary, replace the transmission fluid every 30,000 to 60,000 miles to ensure smooth gear shifts. 8. **Spark Plugs**: Replace spark plugs every 30,000 miles to maintain fuel efficiency and engine performance. 9. **Suspension and Steering**: Regularly inspect the suspension and steering components to ensure a comfortable and safe ride. By adhering to this maintenance schedule, you can help ensure your 2007 Opel Astra continues to perform reliably.
The air conditioning filter in the VS8 is difficult to replace.
How to replace the air conditioning filter?
When you slow down to stop, and the RPM suddenly goes up to around 2000 before dropping, it could be related to the transmission downshifting or the engine management system adjusting for some reason. As for the brakes feeling a bit soft, you might want to check the brake fluid level or have the brake system inspected for air or leaks. If anyone has more insights, please share. Thanks!
What should I pay attention to when maintaining a Vitara 1.4T automatic? Which brand of engine oil and filter is better? How often should the air conditioning filter be replaced? At how many kilometers should the original spark plugs and brake fluid be replaced, and what brand of battery is recommended to be replaced with?
Does the 2021 stock 5008 need a complete fluid change and battery replacement?
Suzuki Swift
Suzuki SwiftOMR 5,200 ~ 6,400Gasoline & Petrol
