علي طلحة
Apr 8
Hey Swift buddies, can someone tell me where the water leak is if there's water accumulating under the rear seat on the driver's side during rainy days? There's no water anywhere else, just this spot on the left side of the rear seat.
Passenger side rear footwell is mysteriously accumulating water, while the other three spots are dry. The headliner is also normal with no water stains. It's just the passenger side rear that's wet! Can anyone help me figure this out?
Why is there water pooling only in the rear passenger seat area, while the roof and other seats are dry, with no water stains?
There might be an issue with the seal or a blocked drainage that is causing water to accumulate under the driver's seat. It's best to check for any leaks in the door seals or windows, and also inspect the drainage system to ensure it's not clogged.
4During the rainy season, my car has been parked outside for the past few days. After starting the car and pressing the brakes, I hear water sounds from the chassis. I've checked the sunroof and there's no leak, also tested the floor, and it's fine. Could it be that the frame has taken in water? Can any expert analyze this?
5How to fix a water leak in the rear hatch ceiling of a 2011 Kia Sportage?
6Hey Swift buddies, can someone tell me where the water leak is if there's water accumulating under the rear seat on the driver's side during rainy days? There's no water anywhere else, just this spot on the left side of the rear seat.
7Help needed! How do I fold down the rear seats of a Suzuki Swift?
8What's causing water under the passenger seat and rear floor mat of the Haima S5? Where is it leaking from? If anyone knows, please reply, thanks!
9My keyless entry only works on the rear side of the driver's seat. Is it broken?
10Has anyone experienced water leaking onto the passenger side from the AC? The AC drain pipe isn't clogged and it's draining water. Could it be that there's water inside the evaporator box?
