عبد العزيز قربان
2024-08-17 18:44
For a 2013 Suzuki Swift, if you're experiencing a buzzing noise at speeds of 40 km/h and above, and the noise gets louder as you go faster, what can you do to reduce the sound? Any advice from experts would be greatly appreciated. Thank you!
خالد عبيد
خالد عبيد2024-08-17 19:01
The axle is broken.
When driving a manual transmission car, if you hear a rubbing noise from the engine slightly above 2000 RPM, but it disappears above 2300 RPM, what could be the reason?
My Peugeot 207's steering wheel is a bit off, and I have to turn it slightly to the right to drive straight. Has anyone else experienced this? How did you deal with it? Any advice would be greatly appreciated. 🙏🙏🙏!
When driving above 80 km/h, there's a noticeable noise near the passenger side A-pillar. At higher speeds, like 120 km/h, the noise becomes even louder.
I have a used Suzuki SX4 AWD with 130,000 kilometers. In extreme cold weather (minus 40), it drives very steadily. However, when the temperature rises to around 5 degrees above zero, it feels a bit floaty and unstable at speeds of 80 to 100 km/h. Can fellow car enthusiasts offer some advice?
When you accelerate above 50 mph, there's a clicking noise, like "ta-ta-ta," but there's no noise when you're not accelerating! I'm not sure what's going on. Looking for some advice.
I have a 2017 V60, and sometimes I hear a clicking noise from the chassis when driving at high speeds. The noise disappears if I lightly tap the brakes. I suspect it might be an issue with the brake system, but I've been to the dealership twice and they couldn't solve it. Has anyone experienced a similar problem? Any solutions would be greatly appreciated!
Hey car enthusiasts, how do you guys shift gears with a 1.3L manual? 2nd gear at 20-40, 3rd at 40-60, 4th at 60-80, and 5th above 80!
Do you have issues with window noise? When the car is parked outdoors, during rainy or very hot days, after starting, there's a creaking sound from the rooftop or windows, which disappears after driving for a while. I should mention that if it's parked in an underground garage, there's no noise. Even after reopening and closing the sunroof, the problem persists. When the noise occurs, it gets louder if the road is uneven. The model is a six-seater.
Hello everyone, may I ask if adding ambient lights and replacing the triple-beam headlights on the Lexus ES300h will cause any noise? A lot of people online say that after disassembling the ES, there will be noise. I would really appreciate your advice! Thank you! 😊😊😊
Suzuki Suzuki Swift
Suzuki SwiftAED 48,900 ~ 60,000Gasoline & Petrol
