2011 1.5L manual sports edition, top configuration, excellent condition. Anyone interested? I'm thinking about switching to an MK4.
Is anyone interested in a 2015 Multivan 4WD with 150,000 kilometers? The car is in excellent condition and has custom-installed aviation seats.
I just got a 2018 Roewe RX5 1.5L automatic deluxe edition. Is it normal that when I turn on the high beam and push the light lever back, it doesn't switch to the low beam? Could something be broken?
I'm looking to buy a 2012 Acura MDX for personal use. I want a vehicle in excellent condition with original parts and paintwork—preferably one that hasn't had any screws touched. My interest in this car is genuine, driven by sentiment and appreciation for its design. I've always thought it looks stylish, and I feel that driving an Acura reflects a unique and tasteful sense of style.
4Hello fellow car enthusiasts, I have a 2016 manual Fengshang edition that's been driven nearly 100,000 kilometers. It's in excellent condition. How much could it be worth?
52011 1.5L manual sports edition, top configuration, excellent condition. Anyone interested? I'm thinking about switching to an MK4.
6Hi, for a 2011 Suzuki Swift 1.5 automatic that's run 110,000 km, here's what you might want to consider for maintenance to avoid getting ripped off: 1. **Oil Change**: Check and replace the engine oil and oil filter. 2. **Transmission Fluid**: Inspect and possibly replace the transmission fluid. 3. **Brake System**: Check the brake pads and brake fluid. 4. **Coolant**: Inspect the coolant level and top up or replace if necessary. 5. **Air Filter**: Check the air filter and replace if dirty. 6. **Tires**: Check tire pressure and tread wear. 7. **Battery**: Test the battery to ensure it's in good condition. 8. **Belts and Hoses**: Inspect for any wear and tear. It's always a good idea to consult your vehicle's manual or a trusted mechanic for specific recommendations.
7Purchase a 2011 1.5 Sport Edition Suzuki Swift.
8Is it worth buying a 2011 Prado 4.0 VX with an adjustable suspension, 220,000 km, used for engineering projects, and in excellent condition?
921 Dark Special Edition, original paint, green, registered in October 2021. Comes with imported Rollypus invisible car film (worth around 30,000). Mileage is 17,000 kilometers, no off-road history, regularly maintained, excellent condition. How much can it sell for? The 21 version has the highest configuration, with a large screen, electric suction doors, and nothing has been downgraded.
10Why does the economy mode in the Tanlu need to be set manually every time, and after turning off the engine and restarting, it automatically switches back to the standard mode? It seems like it can't be configured.
