17 Leading Edition... 220,000 km driven. The engine cylinder head is damaged, causing water leakage. Has any other owner encountered the same issue?
I've never encountered an issue with high water temperature in my car. There's no water leakage. What could be the problem?
417 Leading Edition... 220,000 km driven. The engine cylinder head is damaged, causing water leakage. Has any other owner encountered the same issue?
5I'm asking about the new 009 model regarding the HUD issue. I'm 186 cm tall, and during the test drive, I noticed that the HUD display is not fully visible. The top part is cut off due to the angle. I've already adjusted the HUD to the lowest position, and my seat is also set to the lowest and a relatively back position. Even then, in a normal sitting posture, the top of the HUD is still a bit cut off, and I have to lower my head to see all the HUD information. Are there any other owners with the same issue? Also, can the 009's HUD display information from QQ Music, like selecting a song to play or displaying lyrics?
