1. Does anyone know if it's normal for there to be a "thud" sound when quickly releasing the clutch from first to second gear in a manual Suzuki Swift? 2. When pressing the clutch to engage first gear, sometimes there's a "thud" sound near the left foot. What's the issue?
The gear lever on this company car is problematic. After shifting to reverse, the detent stays in the engaged position even when you return it to neutral. You have to push it down to disengage. I didn't pay attention today, and when coasting downhill while pressing the clutch, I directly shifted to first gear without pushing the detent down. As a result, the car stalled and now it won't start at all.
Is there a continuous "thud thud thud" sound when driving slowly over slightly uneven roads?
Is your 2018 manual KIA Pegas with 70,000 km experiencing difficulty in shifting gears, often failing to engage and grinding? It seems like the clutch isn't fully disengaging. Could this be a clutch issue or a problem with the gear linkage? How can it be resolved?
4When I start my Cayenne, I hear a "thud" sound. How did you guys resolve this issue?
5The clutch on the 2.3T manual Ousheng makes a clunking sound when released halfway.
6At extremely low speeds, there's a crisp sound from the relay contact when kinetic energy recovery engages. In creep mode, it occurs just when the brake is applied during low-speed crawling. Without creep mode, it happens when you release the accelerator at low speeds. It's just one crisp sound, coming from near or in front of the pedal. The sound is very faint, and can't be heard with the windows open, music playing, or on a bumpy road. This is with the first launch of the dual-motor. Has anyone else encountered this issue, and can it be fixed?
7What could be the issue with the 2019 JETOUR X70 having difficulty shifting gears? The clutch master cylinder and transmission have already been replaced, and the issue has somewhat improved. However, sometimes it's still hard to engage first gear.
8I have a 2019 Jeep Compass 1.4T. When I put it in reverse and give it gas, there's a "thud" sound sometimes, but not always. Does anyone know what's going on? I checked with a mechanic, and they said it's normal for a dry dual-clutch transmission. Can anyone confirm this? Thanks.
91. Does anyone know if it's normal for there to be a "thud" sound when quickly releasing the clutch from first to second gear in a manual Suzuki Swift? 2. When pressing the clutch to engage first gear, sometimes there's a "thud" sound near the left foot. What's the issue?
10Is it normal for the Haval Jolion Comfort edition to lurch slightly when you park on a slope, shift to P, engage the electronic handbrake, and then release the foot brake?
