Why does my Sunny manual stall frequently with jerking? I never had this issue before with a manual. Could it be that the clutch needs replacing?
What could be the reason for the idling vibration in a Nissan Sunny manual transmission? I've replaced the spark plugs, but it hasn't solved the issue.
Is the jerking in the 13 model caused by needing a transmission oil change? I've never changed it in over 90,000 kilometers. 🤦♂️
I've reached 100,000 kilometers. Do I need to replace the clutch kit?
4Is it normal for a fan not to spin frequently? I had it replaced at a friend's shop, but it's still the same.
5I want to ask fellow car enthusiasts, for those with dual-clutch transmissions, does your engine shake like a manual car about to stall when you're in a traffic jam?
6Can the original engine oil of the 90 Zilong Edition last for 10,000 km before needing a change? Changing it every 5,000 km seems too frequent.
7Is the clutch very heavy? Do I need to replace the clutch kit, or should I replace something else? Or is this normal? It's a 2014 model with over 200,000 kilometers, and I just got it as a used car.
8Why does my Sunny manual stall frequently with jerking? I never had this issue before with a manual. Could it be that the clutch needs replacing?
9How many kilometers can the clutch slave cylinder of a manual Sunny typically last? Mine seems a bit off, but the gear shifting is all normal.
10How many kilometers before the timing belt of the Volkswagen Santana needs to be replaced?
