حسن عباد
2024-10-07 19:16
Why does it feel like the ground clearance of the Sunny is quite high? Looking at the Accord, it seems lower than the Sunny. I wonder if it's just a visual thing or if older cars are generally higher than the newer ones.
سلمان أم
سلمان أم2024-10-15 12:56
It's indeed high, convenient for getting over curbs.
سعود أمير
سعود أمير2024-10-12 08:50
I only consider older cars with higher ground clearance, never the ones with lower clearance.
عمر فايز
عمر فايز2024-10-08 07:43
The chassis of older cars is generally a bit higher.
Which car has a higher ground clearance compared to the GT? Considering the road conditions are quite challenging. 🤔
With a budget of 140,000, I'm considering buying a used 7-seater MPV. I'm currently looking at the 2018 imported Volkswagen Sharan and the 2015 Honda Elysion Luxury Edition. I drive about 10,000 kilometers a year. Which one should I choose? The Sharan is newer, has good safety features, and strong power, but maintenance and repairs are expensive, and it requires 95-octane fuel. The Elysion is older, but can run on 92-octane fuel, has lower maintenance costs, is more common, and retains its value well.
Is the hood of the Grand Cherokee lower on the right side? When sitting in the driver's seat and the passenger seat, the hood seems to have different heights. From the passenger seat, the right side of the hood appears to have a greater curve, but from the driver's seat, the left side doesn't seem to have as much curve as the right. The car is parked on level ground, and the seats are adjusted the same, but the issue persists. However, when viewed from outside the car, there seems to be no problem. Is this a visual perception issue?
How's the ground clearance of this car? My current ES always scrapes the speed bumps when I drive to the industrial area. Is this one any higher?
Nissan Nissan Sunny
