avatar-image
نايف عاطف
Dec 13
What could be the reason for the idling vibration in a Nissan Sunny manual transmission? I've replaced the spark plugs, but it hasn't solved the issue.
أحمد مكرم
أحمد مكرم2024-05-08 21:48
Start by eliminating one issue at a time. First, clean the throttle body, then check the ignition coils. Ensure the idle motor is functioning properly. Also, consider if the car has high mileage. Check for serious carbon buildup in the intake manifold and whether the air flow meter is working correctly. It's recommended to find a reliable repair shop for an inspection.
عبدالله حازم
عبدالله حازم2024-05-05 23:05
Same here, the mechanic said it's hard to fix.
أحمد خدي
أحمد خدي2022-02-27 17:57
Replace the engine mount. Check the fuel pump. Clean the throttle body.
Nissan Nissan Sunny
Nissan SunnyAED 48,500 ~ 81,500Gasoline
