سعود ميك
2024-04-14 22:00
There's a scraping noise coming from the right front wheel of your 2013 Nissan Sunny, and it's particularly loud when you brake. It sounds like metal scraping. The car has done 150,000 kilometers, and the brake pads are of moderate thickness. The repair shop says there's no need to replace them. What could be the issue?
حسن بندك
حسن بندك2024-04-16 15:58
When you hear a metallic sound while braking, it's usually because the brake pads are grinding against the brake drum. It's recommended to replace the brake pads. If you delay fixing this, it could damage the brake drum.
نايف طائي
نايف طائي2024-04-16 15:06
Take a look at the CV joint. There are still some places where it's wearing. Lift it up and take a closer look.
When braking to a low speed, there's a metallic noise. Does anyone know what's going on??? The brake pads were just replaced two or three months ago.
How many kilometers do you guys usually change your brake pads? Yesterday, during maintenance, the technician said the brake pads need to be replaced, but I've only driven 40,000 kilometers. Shouldn't need to change them yet, right?
During driving, the 2016 Peugeot 301 makes a loud scraping noise from the undercarriage. It happens once every few miles. Sometimes it occurs when turning or braking, but most of the time it's quiet. What could be the issue?
Hey car enthusiasts, my 2011 manual Alto has done over 70,000 kilometers and needs new front brake pads. Could you recommend a good quality brake pad for me to check out? Thanks!
Hi everyone, I'm looking for advice from fellow Grand Cherokee owners. A braking distance of 43 meters seems pretty bad. Has anyone done any modifications? What brands did you use? Is it enough to just replace the brake discs, calipers, and pads? What's the braking distance after modification? Also, has anyone switched to LED headlights? How's the performance? Which brand did you go with?
How to fix the long brake travel on a 2014 Santana? The brake pads are thick, the rear drum brakes have been tightened, and the brake fluid has been changed. Recently, the brake travel has become longer, and I'm not used to it at all. When I press the brake, it feels like there's a hissing sound under my foot. Several mechanics said they can't adjust it. Any suggestions on which part needs to be replaced? Thanks!
I picked up my Nissan X-Trail Classic in March '24. While driving, I always feel the brake pedal makes a loud noise when it rebounds, especially when I release the pedal quickly.
Is it normal for the brake pedal of the Nissan X-Trail Classic to make a loud noise when it rebounds and contacts the brake light switch?
Hello everyone, when driving an automatic Nissan Sunny, what's the situation when I brake and then accelerate, the RPM goes high but the car doesn't move? This often happens when turning as well, the RPM is high but it just doesn't go.
Nissan Nissan Sunny
