It seems that the 2011 Nissan Sunny doesn't have an engine immobilizer. I can just use a mechanical key to unlock the door and drive away.
My GA6 used to automatically unlock when the key was near the door and lock when the key moved away. Now it's not working. Any suggestions?
It seems like your 2011 Phaeton is experiencing some issues with the remote unlocking and the keyless start system. Sometimes you have to use the mechanical key to lock and unlock the car, and the keyless start doesn't work. Occasionally, after using the mechanical key to start and then turning off the engine, the remote unlocking and keyless start work fine again. What could be the problem?
The car wouldn't start just now, and the screen didn't light up. I couldn't unlock it with the key fob either, so I had to manually turn the car door open with the key.
4Is there anyone interested in buying a September 2011 Nissan Sunny automatic for sale?
5Does the 2011 Nissan Sunny manual model have an engine immobilizer with a security code? It seems like a mechanical key alone can start it. Does it not have a central engine immobilizer system?
6I want to ask what size is the oil pan screw for the 2011 Nissan Sunny? Is it 14?
7Where is the temperature gauge in the 2011 Nissan Sunny 1.5XE manual comfort version?
8It seems that the 2011 Nissan Sunny doesn't have an engine immobilizer. I can just use a mechanical key to unlock the door and drive away.
9The car hasn't been driven for just two days, and the door can't be unlocked. I used the mechanical key to open the door, but there's no power at all inside. What's going on?
