فهد جعفري
2024-03-13 22:52
Is it worth buying a 2011 automatic high-end 1.5 with 110,000 km for 18,000? The front windshield has been replaced, and the rear air vent can't blow warm air. I didn't look into other details. I took a short drive and didn't notice anything unusual.
عمر فايز
عمر فايز2024-03-17 14:02
The price is very cost-effective. If the car model is okay, you can go for it decisively. The rear air vent is just a fan without hot or cold air, a bit of a useless design, but it doesn't matter. My 2011 1.5 CVT low-end model is still running strong, fuel-efficient with plenty of space, perfect for family use.
خالد ربيع
خالد ربيع2024-03-14 12:54
It seems like there's a car for sale in this group for 14,000. The rear seats don't have a heater, and the car's heating and cooling system tends to break easily.
Will changing the air conditioning vent show the temperature if it didn't before? Has any fellow car enthusiast modified this?
The rear air conditioning vents are not blowing cold air?
For the 2017 GWM Haval model with 110,000 km, if the air conditioning isn't blowing air until the fan speed is set to maximum, or the AC needs to be turned off for a few seconds before air comes out, there might be an issue with the blower motor or the air vents. It's best to have a professional check the blower motor and the vent system for any blockages or mechanical issues.
The air conditioning in my 2019 model Yueshang only blows air towards the front windshield, while there's no air coming from the center console or side vents. Does anyone know what might be causing this issue, and is it complicated to repair?
I've got a 2014 Grand Cherokee, and lately when I turn on the heater, the driver's side vent blows cold air while the passenger side vent blows warm air. Does anyone know what might be causing this?
Is anyone else experiencing an issue with the footwell air vent on the Aion? Even after turning off the footwell vent on the control panel, cold air still blows on my ankles. It's really uncomfortable on a long drive. Anyone else having this problem?
Is the warm air blowing on the windshield of your LC120 also weak?
Is the warm air blowing on the windshield of your LC120 also feeling weak? Is it the same for you guys?
Nissan Nissan Sunny
