Is it normal for a 2015 Nissan Sunny manual transmission, with 80,000 kilometers, to have the RPM at 2000 when going over 70 mph in fifth gear?
I'm considering getting an Acura and want to ask fellow car enthusiasts: What's the RPM at 100 mph in fifth gear for an Acura? And in sixth gear, what's the RPM at 100 mph? Thank you all!
When driving at speeds between 50 to 70 km/h, should I use fourth gear or fifth gear? I've just got my license.
I bought an '09 Accent and it's burning oil. What should I do? At 80 mph, the RPM is over 2000, and when I accelerate more, it vibrates a bit. Is there a problem? Can it go on the highway?
4When driving a manual 1.5L Mazda in fifth gear at 80 km/h, what is your engine's RPM?
5Why can't the Pajero burn out when the brake is fully pressed and the accelerator is fully pressed in D gear, with the RPM only reaching a bit over 2000?
6Is it normal for a 2015 model to have a smooth start without accelerating, but require around 2000 RPM to start with acceleration, and then feel a noticeable jolt and tire slip?
7Has anyone experienced this: when driving normally and approaching a traffic light, you brake and almost come to a stop but not completely, and at around 10 mph the RPM fluctuates while the gear has already dropped to second gear?
8Is it normal for a 2003 Nissan Sunny 2.0L to run 300 kilometers on 34 liters of fuel?
9What is the normal RPM for a 2015 manual Nissan Sunny in fifth gear?
10Is it normal for a 2015 Nissan Sunny manual transmission, with 80,000 kilometers, to have the RPM at 2000 when going over 70 mph in fifth gear?
