If the yellow engine light on your dashboard is illuminated, it could be due to several reasons, especially since you recently changed the battery on your 2014 second-hand car. Here are a few steps you can take:
1. **Check the Gas Cap**: Sometimes, a loose or damaged gas cap can trigger the engine light. Make sure it's tightened properly.
2. **Inspect Recent Changes**: Since you just replaced the battery, ensure all connections are secure and there are no loose wires.
3. **Diagnostic Scan**: Consider using an OBD-II scanner to read any error codes from the car's computer. This can give you a clearer idea of what might be wrong.
4. **Consult a Professional**: If you're unsure or the light persists, it might be best to consult a mechanic to diagnose the issue properly.
Changing the battery can sometimes reset the vehicle's systems, causing the light to come on if there are underlying issues.
خالد ربيع2024-11-30 15:20
My car's warning light is on, it's likely an issue with the catalytic converter. You should have a mechanic check it out.
خير الدين حسين2024-11-30 10:46
Normally, changing the battery won't trigger any warning lights.
2
نايف طائي2024-11-30 07:47
Changing the battery usually doesn't trigger a fault. If there are no obvious symptoms, first go to the 4S shop and check the fault codes to see where the combustion isn't good. There are many reasons for the warning light, it's hard to determine right now.
