عمر فخرو
2024-04-06 19:50
If the external circulation of your car's air conditioning system can't switch to internal circulation, it might be due to a problem with the actuator or a control switch. The cost for repair can vary depending on the make and model of the car and the specific issue. I recommend consulting a local mechanic for an accurate diagnosis and cost estimate.
خالد ربيع
خالد ربيع2024-04-06 21:39
The part itself isn't expensive, but the entire dashboard needs to be disassembled, which makes the labor cost high. It's just a plastic gear.
If you're considering switching to a Model X, the delivery time can vary depending on your location and the specific configuration you choose. Typically, it might take a few weeks to a few months for delivery. It's best to check directly with Tesla for the most accurate and up-to-date delivery estimates.
The 2015 Volkswagen Touran with an automatic transmission uses a timing belt. It is typically recommended to replace the timing belt every 60,000 to 100,000 kilometers, depending on the manufacturer’s specifications and driving conditions. Always refer to the vehicle's manual or consult with a professional mechanic for the most accurate information.
Hi everyone, I've got an '07 model practice car. When I turn on the internal circulation switch, the light comes on, but there's no circulation effect. What's going on?
Is it possible to set the car to default to internal circulation instead of external circulation when starting?
Nissan Nissan Sunny
