محمد شعبان
2024-08-23 10:21
I've been driving my car for six years, and it's covered over 30,000 kilometers. Recently, while driving, the gear indicator on the dashboard disappeared, and the engine warning light came on, but the car was still running fine. I went to a repair shop for a check, and they said there was no problem and cleared the warning light. However, the warning light appeared again soon after, and the gear indicator keeps disappearing intermittently. Additionally, there's shaking when braking to a stop and when starting the vehicle. I'm seeking advice from the community!
علي محمد
علي محمد2024-09-11 10:37
The issue might be with the transmission. Check the coupler; my problem was quite similar to what you described.
سعود مهدي
سعود مهدي2024-09-11 09:21
Try replacing the brake light bulb.
The tire pressure warning on the third-generation Yuexiang keeps appearing. After driving for a while, it disappears. What's going on??
My manual Kia Pegas has run over 20,000 kilometers. This afternoon, the malfunction indicator light kept coming on. I turned off the car and restarted it, but the light is still on. Seeking advice from fellow car enthusiasts.
Why did the engine warning light turn on and the D gear light keep flashing after driving my 2014 Honda City automatic on the highway for three hours?
My car is 3 years old and sometimes it shows a right front indicator fault, but then the warning disappears. I've had it checked at the shop, but they couldn't find the cause. Has anyone else experienced a similar issue?
I have a question for everyone. Occasionally, when opening the door of my 2021 Subaru Outback, the hazard lights flash a few times accompanied by a beeping sound, then it disappears. There's no indicator light on the dashboard, and there's no issue while driving. What could be the reason for this? I've been driving it for a few years and it's the first time I've encountered this situation.
The dashboard shows a warning light, and when checked with a computer, it indicates an ignition module issue. Should I replace the ignition coil? There are no problems when driving normally.
I have a 2016 Haval H2. Have any of you experienced a brake light fault warning when pressing the brake pedal for a long time, but the warning disappears once you restart and press the brake again?
Nissan Nissan Sunny
