I tried upgrading my Nissan Sunny's low-spec dashboard to a high-spec one, but it failed due to a loose connector. Now, I can't even reinstall the original low-spec dashboard because the wiring is all messed up. Can anyone provide the dashboard wiring information? What should I do? Help needed 😭😭😭I tried upgrading my Nissan Sunny's low-spec dashboard to a high-spec one, but it failed due to a loose connector. Now, I can't even reinstall the original low-spec dashboard because the wiring is all messed up. Can anyone provide the dashboard wiring information? What should I do? Help needed 😭😭😭
عمر فايز
2024-07-15 22:02
عمر فايز
عمر فايز2024-08-21 19:36
The interface sorting data corresponds to the above two sets for the low and high configurations. Initially, I couldn't get it right because two wires touched each other, causing the fuse to burn out. After replacing the fuse, everything works perfectly.
محمد رضوان
محمد رضوان2024-08-20 23:54
Has it been resolved? I'm also thinking about making changes, but I'm not sure how to do it.
2
Can I upgrade the fuel consumption display and mileage gauge on my 2016 manual Kia Sportage, which is a low-spec version?
I recently replaced the headlight assembly on my Kia 2009 Sportage, and now I'm facing two issues: 1. The headlights can't switch between high and low beams. 2. The headlight level adjustment switch on the central control dashboard is not working; turning the switch doesn't affect the headlights.
The dashboard reported low transmission performance, and then the car wouldn't accelerate. After restarting, the warning light went off and it drove normally. What could be the reason? (The onboard computer cleared the fault light, but it came back on before I got home.)
I have a Mini Clubman 2.0T, and when starting or at low speeds, I hear a kind of loose rattling sound, similar to a "license plate not tightened" noise, when I press the accelerator. I'm not sure where the sound is coming from. Does anyone else with a Mini experience this?
Hi everyone, I've been having issues with my Hongqi H7 where the side mirrors often don't fold when I lock the car and the seat adjustment occasionally fails too. I noticed these problems tend to occur together. I had the wiring checked and charged the battery, which fixed it for a while, but then it started happening again. I thought it might be the battery losing charge, so I replaced it. It was fine at first, but then the problems came back. The mirrors fold manually without any issues inside the car; it's just when I lock the car that they don't fold, and the seat adjustment also fails!
Who knows how to turn off adaptive high beams? I set it up and found that when I manually turn on the low beams, the dashboard indicator light goes off, and I still can't figure it out.
I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
After replacing the battery on a 2017 Skoda Octavia 1.6 manual with low trim, the trip mileage, average fuel consumption, and other information on the dashboard reset to zero every time I lock the car for about 2 hours and then start it again. Has anyone encountered this issue or knows how to fix it? Please let me know. Thanks.
Nissan Nissan Sunny
