I'm driving a 2013 Sunny with a manual transmission, high trim. The halogen lights really don't seem bright enough. I checked on Pinduoduo, but I'm hesitant to buy from there. Has anyone bought lights from there? Can any of you guys recommend something you've used? Driving at night is tough; oncoming high beams make it hard to see anything. 🙈 Can you recommend some good combined high/low beam lights?
Hi everyone, I'm looking to upgrade the halogen headlights on my 2014 Yizhi to LED ones because they're not bright enough. Any good recommendations? Thanks!
I feel like the high beam is aiming a bit high. Is there a switch in the car to adjust it? I've looked around but couldn't find anything.
Is the headlight of the 2019 Changan Alsvin automatic a combination of low and high beam, or are they separate? I'm thinking about changing the bulb recently!
4The headlights are not working, but the high beams are bright. Why is this happening?
5Do you have any recommendations for suitable license plate lights for the 2018 Legacy? The original halogen ones are really ugly.
6Today, I'm not sure what happened. The headlights and high beams are not working.
7Could you recommend a car light? I feel like my current ones aren't bright enough.
8Looking to upgrade the headlights. The original ones really don't cut it for high beams. Any recommendations?
9I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
10I'm driving a 2013 Sunny with a manual transmission, high trim. The halogen lights really don't seem bright enough. I checked on Pinduoduo, but I'm hesitant to buy from there. Has anyone bought lights from there? Can any of you guys recommend something you've used? Driving at night is tough; oncoming high beams make it hard to see anything. 🙈 Can you recommend some good combined high/low beam lights?
