I can't connect the Bluetooth system of my 2014 Nissan Sunny with my phone. It says the key or pairing code is incorrect. Does anyone know how to connect the phone to the Bluetooth?I can't connect the Bluetooth system of my 2014 Nissan Sunny with my phone. It says the key or pairing code is incorrect. Does anyone know how to connect the phone to the Bluetooth?
فهد ماجد
2024-10-08 19:17
عمر فايز
عمر فايز2024-10-08 23:08
Replace the Android head unit.
2
How do I play music via Bluetooth? Do I need to connect it with my phone?
Can this car's infotainment system connect to a phone via Bluetooth?
How do I connect Bluetooth with my phone?
I just want to ask how to connect my phone to Bluetooth.
Can't the Phaeton connect to Bluetooth?
Does the Vitara have Bluetooth connectivity for phones?
I've been using my KAMIQ for 3 years, and now the car's Bluetooth can't connect to my phone, so I can't answer calls. What's going on?
I have a 2021 Diamond Edition Fengxing T5EVO. After changing my phone, the app's Bluetooth won't connect to the car, and I can't unlock the car with my phone either. The app keeps crashing. What could be the reason?
Nissan Nissan Sunny
