فهد يعقوب
2024-05-02 19:26
How often should transmission fluid be changed?
Comments( 8 )
سعود شفيع2024-06-09 15:05
If you have a CVT transmission, change it every 40,000 kilometers. For a dual-clutch transmission, change it every 50,000 to 60,000 kilometers. For an AT transmission, change it every 40,000 to 60,000 kilometers.
سعود ميك2024-06-01 11:11
Manual transmission, haven't changed it even at 150,000.
خالد بندر2024-05-31 08:08
Driven for 135,000 kilometers, used for over 12 years, manual, never replaced.
حسين علي2024-05-26 14:20
How often should manual transmission oil be changed, and which brand is better?
حسن عباد2024-05-13 22:11
Does this transmission fluid differentiate between automatic and manual?
نايف ممدوح2024-05-13 06:27
I've reached 90,000 km, and I still haven't changed it.
20
عمر حميد2024-05-09 22:22
I bought it for 70,000. The boss accidentally asked, "Your car should have 100,000 kilometers on it, right?" [I need a moment]
فهد لاويل2024-05-03 06:55
I exchanged it for 80,000.
Does anyone know how often the transmission oil should be changed for a gasoline Korando?
I've driven 80,000 km. Is it time to change the transmission fluid? What type of fluid should I use?
How often should the gear oil be changed for the Rapid?
4How often should differential oil be changed?
5How often should the transmission fluid be changed? It's been almost two and a half years, and I've driven nearly 40,000 kilometers. The dealership suggests replacing it.
6How often should the transmission fluid be changed?
7How often should transmission fluid be changed?
8How often do you guys change brake fluid? Looking for advice!
9How often should the transmission oil be changed?
10How often should brake fluid be changed?
