خلدون سعود
2024-06-19 16:23
How many kilometers can the clutch slave cylinder of a manual Sunny typically last? Mine seems a bit off, but the gear shifting is all normal.
نايف طائي
نايف طائي2024-06-19 16:33
If you don't change the brake fluid frequently, it can lead to issues like poor spring reset. Replacing the brake caliper should solve the problem.
Is your 2018 manual KIA Pegas with 70,000 km experiencing difficulty in shifting gears, often failing to engage and grinding? It seems like the clutch isn't fully disengaging. Could this be a clutch issue or a problem with the gear linkage? How can it be resolved?
Hey folks, have any of you experienced clutch master cylinder oil leaks? It seems like the leak is at the connection between the master cylinder and the oil pipe. Is this a common issue?
MG3 2013 model 1.3L manual. Around July last year, the clutch wouldn't spring back, so I replaced the clutch kit. Recently, with the hot weather, the issue has reappeared several times. When the car heats up, the clutch rebound is particularly slow, and after a while, it won't rebound at all. If I park by the roadside for a bit, it gets slightly better. There's also a strange noise when pressing the clutch.
Mitsubishi ASX owners, can you advise how many years a new car battery typically lasts?
Fellow car enthusiasts, have you experienced slow shifting between the 6th and 7th gears with your 7-speed dry dual-clutch transmission? Mine doesn't shift to 7th gear even at 80 km/h and waits until it reaches 85 km/h. Is this normal?
What could be the issue with the 2019 JETOUR X70 having difficulty shifting gears? The clutch master cylinder and transmission have already been replaced, and the issue has somewhat improved. However, sometimes it's still hard to engage first gear.
The car stopped in the middle of the road, with 25,000 km mileage. Couldn't shift gears, and the clutch felt heavy. Surprisingly, it was fine the next day. Decided to replace the clutch slave cylinder for 240 RMB. 🤷‍♂️
My Tianyu SX4 is a manual transmission, and the gear shifting feels a bit heavy. How can I fix this?
Hey fellow car enthusiasts, do all fuel-powered cars experience jerking when shifting gears? Mine does when shifting from 1st to 2nd. In this situation, will the dealership replace the electro-hydraulic module?
Nissan Nissan Sunny
