How is this brand A engine oil? Has anyone used it? How many kilometers do you change it?
I've driven 80,000 kilometers. Do I need to change the transmission oil? Which brand of oil should I use?
How many liters of oil does a 1.5T engine need to be changed? Is it easy to do it yourself?
What brand and model of engine oil do you all use?
4How is this brand A engine oil? Has anyone used it? How many kilometers do you change it?
5Has anyone changed their transmission oil? How many liters did you use, and did you do a gravity change or a complete flush?
6Has anyone changed their transmission fluid? How many liters did you use? Did you do a gravity change or a full cycle change???
7Hey guys, quick question. Has anyone with the 2021 Diamond Edition upgraded to LED lights? Did you change the lenses too? Also, for those who do maintenance outside the dealership, what brand of engine oil are you using?
8How many kilometers should you typically change the transmission oil?
9When did you all change your transmission oil, and at how many kilometers?
10How many kilometers do you guys usually change the timing belt?
