Hi everyone, I have a question about my 2016 Nissan Sunny. Sometimes the car won't start on the first try, but if I turn the key off and try again, it starts. This happens every time I start the car. I've had the battery checked and it's fine, and I've also had the starter cleaned and maintained, but the problem persists. Does anyone know what could be causing this issue?
The car has power, but it doesn't start when you try to ignite. What could be the cause, and where should I start checking?
I've only had my car for ten days, and it won't start. Checked the battery, and it's fine. Not sure what's wrong.
Has anyone experienced starting issues with their car? This problem has been going on for over a year. I've replaced the battery, cleaned the fuel lines, changed the spark plugs, and replaced the fuel pump, but still can't find the issue. The dealership is also at a loss. Every time I try to start the car, it takes three attempts to get it running. It feels like the fuel isn't reaching the engine when starting. I'm now afraid to drive, because if the engine stalls, it'll take three attempts to start it again. 😢😢😢 Does anyone know the reason?
4Why do I have to manually enable the network every time I start the 2019 GS5?
5My 207 keeps burning out the starter motor. In the past year, I've already replaced two, and today it burned out again, even started smoking. It feels like just replacing the starter motor isn't solving the root problem. Any fellow car enthusiasts know how to fix this?
6I have a 2016 Honda City, and sometimes it doesn't start on the first try, but it starts on the second attempt. Experts, what could be the problem?
7Why does my Sunny manual stall frequently with jerking? I never had this issue before with a manual. Could it be that the clutch needs replacing?
8Hi everyone, I have a question about my 2016 Nissan Sunny. Sometimes the car won't start on the first try, but if I turn the key off and try again, it starts. This happens every time I start the car. I've had the battery checked and it's fine, and I've also had the starter cleaned and maintained, but the problem persists. Does anyone know what could be causing this issue?
9When starting a 2005 Prado 2.7 from a cold start or after it's been sitting for about half an hour, there's a strange noise. I've already replaced the starter motor, but the issue persists. Does anyone have any ideas on what might be causing this?
10I have a 2005 Prado 2.7. When the car is cold or has been parked for about half an hour to an hour, there's a strange noise when starting. I've replaced the starter with a new one, but the problem persists. I'm looking for some advice to help identify where this noise might be coming from.
