خالد فؤاد
2024-10-08 08:11
Hey everyone, quick question: What's the outer diameter of the exhaust pipe for a Nissan Sunny? Need to buy a fire cap to put on it.
Is the left side of the Jeep Compass exhaust pipe naturally lower, or does it need to be fixed?
Do you need to modify the exhaust header on a new car? Replace the GPF with a straight pipe? Prevent blockage?
Hello everyone! My 11-year-old Sunny with a manual transmission has run 100,000 kilometers. Do I need to change the belt now?
What should I do if the sunroof of my 2011 Nissan Sunny is rusted? I bought a second-hand car. Does it need repair?
There's a scraping noise coming from the right front wheel of your 2013 Nissan Sunny, and it's particularly loud when you brake. It sounds like metal scraping. The car has done 150,000 kilometers, and the brake pads are of moderate thickness. The repair shop says there's no need to replace them. What could be the issue?
Hi everyone, I have a question about my 2016 Nissan Sunny. Sometimes the car won't start on the first try, but if I turn the key off and try again, it starts. This happens every time I start the car. I've had the battery checked and it's fine, and I've also had the starter cleaned and maintained, but the problem persists. Does anyone know what could be causing this issue?
I tried upgrading my Nissan Sunny's low-spec dashboard to a high-spec one, but it failed due to a loose connector. Now, I can't even reinstall the original low-spec dashboard because the wiring is all messed up. Can anyone provide the dashboard wiring information? What should I do? Help needed 😭😭😭
Hey everyone, quick question: When I bought the Toyota Levin Hybrid, the dealership offered a lifetime warranty on the power battery. Will not getting maintenance done at the dealership affect this lifetime warranty?
Hello everyone, when driving an automatic Nissan Sunny, what's the situation when I brake and then accelerate, the RPM goes high but the car doesn't move? This often happens when turning as well, the RPM is high but it just doesn't go.
Nissan Nissan Sunny
