حسين علي
2024-05-18 22:11
Hey car enthusiasts, can anyone help me out? My 2015 manual Sunny only revs up to 2000 RPM when I floor the gas pedal, and the acceleration feels weak. What could be the issue?
حسين علي
حسين علي2024-07-03 22:57
Hello everyone, I have a question about my 2016 Nissan Sunny. Sometimes when I try to start the car, it doesn't ignite, but if I turn the key off and try again, it works. This happens every time I start the car. I went to the repair shop, and they checked the battery which is fine, and the starter was also cleaned and serviced, but the problem persists. What could be the reason?
أحمد رمضان
أحمد رمضان2024-06-08 19:20
Check the catalytic converter; I had the same issue before.
عبد العزيز صلاح
عبد العزيز صلاح2024-05-29 10:03
You can check if the camshaft position sensor is blocked by engine sludge or something else.
2
خالد ربيع
خالد ربيع2024-05-19 14:43
My clutch plate was damaged before, and it was hard to go above 80 km/h.
Is it normal for a 2015 model to have a smooth start without accelerating, but require around 2000 RPM to start with acceleration, and then feel a noticeable jolt and tire slip?
For a 2015 diesel Grand Cherokee, besides the original engine oil, what other options are suitable... Also, recently when I floor the accelerator around 2000 RPM, there's a whistling sound. Have any fellow car enthusiasts experienced this?
What is the normal RPM for a 2015 manual Nissan Sunny in fifth gear?
Is it normal for a 2015 Nissan Sunny manual transmission, with 80,000 kilometers, to have the RPM at 2000 when going over 70 mph in fifth gear?
Is your 2015 Jetta also like this, where the RPM only reaches around 3800 when you floor the gas pedal in neutral and doesn't hit 4000?
Hey drivers, anyone know why my car suddenly can't accelerate while driving? I press the gas pedal and nothing happens. 😩😩 Then, when I press the brake and then the gas pedal, it accelerates. What's going on? 😎
Nissan Nissan Sunny
