Looking to buy a 2011-2013 Volkswagen Phaeton 3.6 V6 high-end version, preferably direct contact with the owner.
Hi everyone, for the 2021 Toyota Land Cruiser Prado LTD, how do you switch between high-speed 4WD and low-speed 4WD? When driving in full-time 4WD, do I need to come to a complete stop to switch between high and low-speed 4WD? Thanks!!
Hey everyone, I need some help with my Peugeot 206! Thanks a lot in advance! 1: Is the 2007 model with a 1.6L manual engine Euro 2 or Euro 3? 2: How can you tell the difference between the high-end and low-end versions of this car? 3: Why are some interiors white and others black? 4: Why are the instrument panel colors different?
4What do you think about this car with the low-end model at 219,800 RMB, the mid-range model at 239,900 RMB, and the high-end model at 269,900 RMB?
5Why is it that the high-end X and S are about the same, but the low-end X is much more expensive than the S? I really like the X. [crying]
6How can I adjust the high and low beam headlights inside the car?
7I tried upgrading my Nissan Sunny's low-spec dashboard to a high-spec one, but it failed due to a loose connector. Now, I can't even reinstall the original low-spec dashboard because the wiring is all messed up. Can anyone provide the dashboard wiring information? What should I do? Help needed 😭😭😭
8Help Needed: 2011 Nissan Sunny Low-End to High-End Instrument Panel Upgrade Issue At first: As shown in the picture, I bought a 2012 luxury version of the Sunny instrument panel. I removed the wires from the low-end panel and connected them according to the high-end socket order. Because I enlarged the wire holes when removing them, it led to poor contact. Initially, everything was normal except the fuel gauge didn't display. Could it be due to poor contact? Then, I reconnected the original low-end instrument panel, which led to the time, trip mileage, and fuel consumption resetting every time I started the car. Finally, I got another high-end socket. This time, I arranged the wire order for the high-end socket first, then connected wires from the low-end socket to the high-end socket (this method avoids enlarging the socket and causing poor contact). Now I'm stuck with the following issues: 1. The engine light is on. 2. The turn signal, headlight, and fog light indicators on the instrument panel don't light up, and there's no ticking sound when using the turn signal. 3. Each time I start the car, the time, average fuel consumption, and trip mileage reset. 4. After turning off the car, the tachometer stays at 1, then drops to 0 and returns to 1 when the car is started again, which seems normal. Everything else seems normal. Could fellow forum members help analyze what the problem might be? I'm almost crying.
9How do I switch the pointer instrument panel to a digital display on the Setus 1.5 Prestige?
10Does the 2019 Ford Territory's instrument panel show when the low beam is turned on?
