Hello to all the Sunshine car owners in the circle. I have a question: What could be the reason for my car's idling stutter, stutter when accelerating, and steering wheel shaking when braking? Please, I would appreciate any help with this.
When the car is idling, it feels like it's shaking, but when I shift to neutral, it doesn't. Does anyone know what might be the reason?
Does your steering wheel shake a lot when you brake at speeds over 60? Have any of you experienced this phenomenon?
4The engine is noisier at idle compared to other cars, and the fuel consumption isn't low. What could be the issue? Any advice would be appreciated, thanks.
5What could be the reason that the brake pedal cannot be pressed down when turning the steering wheel fully or reversing?
6When the steering of the 2017 Honda City is turned fully, there is a stuttering, as if it's stuck, but there is no issue with small turns. What could be the reason for this? Can anyone help with this? Thanks a lot.
7Does anyone else's 2008 occasionally shake when braking?
8My Pang Ge has suddenly started to shake at idle these past two days. Went to the 4S shop and changed the high-pressure fuel pump, checked other areas too. It doesn't shake when driving, doesn't shake when braking with gear engaged, but shakes when in neutral. It shakes as if I'm braking. Can any experts help me figure this out?
9What could cause a 2017 Jetta 1.5 manual to have engine shaking when cold and stuttering on idle start? It's only done 90,000 km. 😊
10Hey car enthusiasts, quick question. When I switch from N to D while idling and press the brake, the car jerks a bit. It's a new car, is this normal?
