Sunny brakes are good or weak, i travel a lot and worried from this matter
I need help from everyone. When shifting from neutral to D gear, there's a noticeable jolt. What's causing this issue? Thanks a lot!
Can I buy a 2020 Changan Yuexiang or a 2015/2016 Nissan Sunny from Link Co., and do they have many minor issues?
I'm looking to buy a 2018 Land Cruiser 4000 in good condition. Mileage doesn't matter, but I want to avoid dealerships. 🤦♂️🤦♂️🤦♂️
4Hey guys, I just got my Es2000 recently, and there's a clunking noise when I brake. It seems to be coming from the brake calipers. Do any of you have the same issue?
5I want to ask, I'm planning to buy a Model X but I'm worried about the risk of brake failure.
6There's a scraping noise coming from the right front wheel of your 2013 Nissan Sunny, and it's particularly loud when you brake. It sounds like metal scraping. The car has done 150,000 kilometers, and the brake pads are of moderate thickness. The repair shop says there's no need to replace them. What could be the issue?
7Hey car enthusiasts, can anyone help me out? My 2015 manual Sunny only revs up to 2000 RPM when I floor the gas pedal, and the acceleration feels weak. What could be the issue?
8Braking Dipping. I'm considering getting a standard 911. After a test drive of the 4S, I noticed a braking dipping issue. Even if I slowly release the brakes at the last moment, there's still a forward lurch just before coming to a stop. My current Mercedes doesn't have this issue, and neither did the Panamera I test drove earlier. Is it a matter of selecting the wrong mode, or is the car designed this way?
9Is Zeekr really good or not? I see a lot of negative comments.
10How to fix the long brake travel on a 2014 Santana? The brake pads are thick, the rear drum brakes have been tightened, and the brake fluid has been changed. Recently, the brake travel has become longer, and I'm not used to it at all. When I press the brake, it feels like there's a hissing sound under my foot. Several mechanics said they can't adjust it. Any suggestions on which part needs to be replaced? Thanks!
