After cleaning the throttle body yourself, the engine warning light came on. It doesn't affect driving, but how can you resolve this?
Even after replacing the spark plugs, camshaft sensor, and cleaning the throttle body, my 2014 Peugeot 301 is still having trouble starting. Any ideas on what could be the issue?
DIY Cleaning of Toyota Verso Throttle Body
Has anyone experienced the engine warning light flashing and the vehicle shaking? It gets better after a while.
4Do I need to perform adaptation after cleaning the throttle body?
5Hello fellow car enthusiasts, have any of you cleaned the throttle body before? I've heard that cleaning the throttle body on an MG3 is quite a hassle, taking up to 5 hours and costing 500 bucks.
6Hey guys, how do you clean the throttle body on your MG3?
7The car is a 2015 model and has run 99,000 kilometers. The warning light turned on, and you replaced 4 ignition coils and 4 spark plugs. After some time, the light came on again, and the engine shakes when starting, but it's still drivable, though the light remains on. What's causing this issue?
8The engine warning light is on, and the idle seems unstable. The speed can still go up, but it doesn't accelerate as quickly as before. Could it be a problem with the throttle? Any insights?
9After cleaning the throttle body yourself, the engine warning light came on. It doesn't affect driving, but how can you resolve this?
10Hello car enthusiasts, does the 2021 Jeep Compass 1.3T need a throttle body cleaning?
