حسن صادق
2022-06-02 10:40
Why does the official spec say the car has a 65L fuel tank, but I can only fill it up with just over 30 liters?
Comments( 11 )
عبدالله إلياس
عبدالله إلياس2023-05-18 11:41
It's a 2016 car, model year 2013. When the fuel tank is left with 2 to 3 bars, it usually takes about 320 to 340 to fill up. I've refueled with fuel prices ranging from 7.4 to 7.9, and the fuel gauge shows 37 to 42 liters.
عبد لطيف فهد
عبد لطيف فهد2023-05-13 12:44
Before the 2012 model, the tank was 65L. Starting from the 2013 model, it's 58L. I have the 2013 base model, and I usually add about 50L after the fuel light comes on.
عبد العزيز جعفري
عبد العزيز جعفري2023-04-20 09:09
Yours is a counterfeit.
عبدالله عباس
عبدالله عباس2023-04-18 13:43
After the automatic shut-off, you can still squeeze in 10 liters of fuel. [I want to be alone]
حسين ياسر
حسين ياسر2023-03-14 15:20
You're all rich [I want to be alone] I only add 100 each time [I want to be alone]
نايف رائد
نايف رائد2023-03-13 22:27
I've added over 50.
أسد حسن
أسد حسن2022-11-07 15:18
The light is on, and the pump stops at around 45 liters.
خالد قاسم
خالد قاسم2022-06-03 23:21
My maximum is 45 liters.
حسن خليل
حسن خليل2022-06-03 17:40
I refuel about 43 SAR each time.
عبد العزيز عاطف
عبد العزيز عاطف2022-06-03 11:17
I'm a bit better than you; I can only reach a little over 40, not quite 50.
Why does a 2006 Accent manual consume so much fuel? Filling up the tank for 340 RMB only allows it to run 450 kilometers.
How many liters is the fuel tank for the 2018 Manual Comfort version? The official specification shows 60L, but mine only holds a little over 40L.
What is the fuel tank capacity of the TRD Adventure edition? The specs say it's 87 liters, but I can only fill up about 60 liters. What's going on?
I recently filled up with 48 liters of fuel and only managed to drive a bit over 310 kilometers, all within the city. Why is the fuel consumption so high, even when using eco mode?
Why does the official website say it has a 700 km range, but when I fully charge it, it only shows a little over 500 km? It doesn't even reach 600 km.
Hey fellow car enthusiasts, my Lancer's fuel gauge is below the red line, but the fuel light isn't on. I can only fill up 37 liters, but isn't this supposed to be a 50-liter tank? Has anyone tested this?
The fuel tank capacity of a Jetta is generally around 55 liters. If you're filling up about 57 or 58 liters each time, it could be due to the fuel already in the tank or variations in pump measurements.
Others are saying that the Tank's fuel consumption is between 6 to 7 liters, but why is my car consuming over 11 liters even though it's just over 5,000 kilometers?
The fuel tank of the Venza Hybrid Premium is labeled as 55 liters, but I can't even fill it up to 50 liters. How about everyone else's experience?
Kia Kia Sportage
Kia SportageAED 97,000 ~ 136,000Diesel & Gasoline
