سلمان دليل
2024-10-19 09:46
When the exhaust pipe of your Kia Sportage only has exhaust coming out from the left side while the right side has very little and cold exhaust, and the right side only works normally when you block the left side, this could indicate an issue with the exhaust system. It might be related to a blockage or malfunction in the exhaust system's design that causes uneven distribution of exhaust flow. It's advisable to have your vehicle checked by a professional mechanic to diagnose and fix the issue properly.
سلمان دليل
سلمان دليل2024-10-29 07:52
One side has a particularly large exhaust, while the other side barely emits anything. You can only feel a slight exhaust on the side that doesn't emit unless you place your hand near the exhaust outlet. The other side, however, emits exhaust quite dramatically.
The steering wheel of the 2016 Crossover Yizhi is not aligned properly and is tilted to the left. The left side is further from the driver, and the right side is closer. Has anyone else experienced this issue, and is there a solution?
Do you hear a sound like two wires colliding under the front left side of the dashboard when driving your Hyundai Reina on bumpy roads? It seems to be related to the steering gear. I've checked the chassis multiple times but couldn't find the issue. Have any of you experienced this problem?
Is the fog light above the taillight on the left side only and not on the right side for the Sienna Platinum version?
Is the left side of the Jeep Compass exhaust pipe naturally lower, or does it need to be fixed?
Are there any owners of the 2018 model using the original car navigation? I want to ask if the power and mute buttons on the left side of your original car navigation work. Why did mine stop working? The volume button on the right side works.
Can I plug a home charger into the fast-charging port on the left side, considering that my parking space has more room on the left and the right side is against the wall?
It sounds like you're experiencing an issue with your 2012 Peugeot 308 not starting, and you're hearing a clicking sound with the onboard computer resetting. Since the battery has been tested and has power, the problem could be related to the starter motor or its connections, the ignition switch, or a potential issue with the car's electrical system, such as a bad ground or corroded terminals. It's recommended to have a professional mechanic check these components to diagnose the exact issue.
Is the automatic anti-glare function for the exterior rearview mirrors on all Ford models only available on the driver's side, but not on the right side?
Is the vibration noise when the wiper of the new ES200 reaches the far left side related to the glass oil film? Does anyone else have a similar issue?
Does the EX30 only have a 12V power outlet on the left side of the trunk, or is there one in the front row as well?
Kia Kia Sportage
Kia SportageAED 97,000 ~ 136,000Diesel & Gasoline
