The Kia Sportage has a jerking sensation when shifting gears.
Is the 2022 GA6 experiencing jerking when shifting from second to third gear and also when accelerating at low speeds in third gear a common issue for this model?
Has anyone experienced gear shift jerking after just replacing the spark plugs and cleaning the throttle? It was fine for two or three days, but then the jerking returned.
What could be the issue if there's a jerking sensation when refueling?
4Is there a 2007 Kia Sportage steering gear available?
5I want to ask everyone, I have a 2022 automatic 86. When shifting from a lower gear to a higher one, there's a bit of a jerking sensation. Is this normal?
6What causes a jerking sensation when gently pressing the accelerator?
7Does your Chery have a jerking sensation when you accelerate or decelerate?
8What should I do about the gear shifting impact in the Yuexiang when it's fine when cold but jerks when hot?
9Does your Jetta automatic also have a noticeable jerk when shifting gears?
10I recently got a CX-5 less than a month ago, and I noticed that when starting the car cold and shifting to D gear, there's a noticeable "jerking" sensation as the car moves forward. After driving for a while and the car warms up, when switching between N and D gear, the jerking sensation is still there but much less noticeable. Is this normal?
