نايف علي
2021-12-20 12:38
Is there a solution for the Kia Sportage valve cover oil leak? Is it a common issue? I bought a 10-year-old manual second-hand car.
Comments( 14 )
عمر سامر
عمر سامر2024-04-03 01:26
Buy a tube of VW sealant on Taobao.
أحمد نوح
أحمد نوح2024-01-19 07:30
I have the same issue with oil leakage.
عبد العزيز مساعد
عبد العزيز مساعد2023-11-16 19:09
Let it go for ten years, don't bother with it.
خالد عين
خالد عين2023-11-16 00:13
Normally, I just replace the seals. I've changed two already [I want some peace], but they're cheap. Just a few dozen bucks.
20
أحمد فاروق
أحمد فاروق2023-11-05 22:54
I spent 200 on replacing an aluminum cover and a gasket. Guys, is this price too high?
نايف بوتفليقة
نايف بوتفليقة2023-10-24 16:34
Let's see what the repair shop suggests.
نايف حبيب
نايف حبيب2021-12-27 13:36
The original car parts are all plastic shells. Replacing them with a pad and some sealant should do the trick. You can also replace it with an aluminum cover.
20
حسن خليل
حسن خليل2021-12-25 12:18
I've also heard that just changing to an aluminum cover will fix it. Mine is leaking oil too.
عبد العزيز ظافر
عبد العزيز ظافر2021-12-25 12:15
I just replaced the valve cover gasket and spark plug seals myself. The old ones were so aged that they turned into hard plastic and made a cracking sound.
محمد إبراهيم
محمد إبراهيم2021-12-21 18:10
Just replace it with an aluminum cap.
Kia Kia Sportage
Kia SportageAED 97,000 ~ 136,000Diesel & Gasoline
