I recently replaced the headlight assembly on my Kia 2009 Sportage, and now I'm facing two issues: 1. The headlights can't switch between high and low beams. 2. The headlight level adjustment switch on the central control dashboard is not working; turning the switch doesn't affect the headlights.
Can the headlight assembly of the 2016 Kaiyi X3 be replaced with separate high and low beams?
What can be used to clean the yellowing edges of the headlight cover on a 2013 Kia Sportage?
How can I check the remaining range for the 2009 manual GL version of the Kia Sportage, and how far can it go?
4I recently replaced the headlight assembly on my Kia 2009 Sportage, and now I'm facing two issues: 1. The headlights can't switch between high and low beams. 2. The headlight level adjustment switch on the central control dashboard is not working; turning the switch doesn't affect the headlights.
5You're considering buying a 2009 automatic Kia Sportage, which was purchased in 2022 in excellent condition for over 40,000. Now, you plan to offer around 13,000 for it. Is it worth buying?
6Does anyone know which emission standard the 2009 Kia Sportage complies with?
7Hey folks, does anyone know how to set the dome light to turn on when the door is opened on a 2009 Kia Sportage?
8Hi everyone, how do I disable the auto lock feature on the 2009 Kia Sportage? I really don't like it!!
9I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
10For a 2012 Kia Sportage with integrated headlights, if adjusting the low beam to the right position causes the high beam to point at the treetops, does anyone know how to solve this? How can the high beam be adjusted lower without moving the low beam?
