خالد عوادة
2023-07-29 21:34
I have a 2015 Kia Sportage. The steering wheel starts to shake when I go over 120 km/h. What's going on? Can anyone help?
حسين عوض2023-09-13 22:38
Wheel alignment and balancing still not working, then check the ball joint and control arm.
سلمان توفيق2023-08-14 11:54
I had a similar issue before, and after checking, I found that the tire had a bulge. You can't feel it at low speeds, but it becomes noticeable at around 110 km/h. You might want to check it out.
حسن أكرم2023-08-01 23:39
My 2012 model does the same. It's been like this for years, no need to worry about it.
Is the heavy steering in the 2015 Kia Sportage 2.0 GL designed to be like this? What do other car enthusiasts think?
Hey folks, has anyone experienced their V40 shaking at speeds between 100 to 120 km/h, but then it stops shaking once it hits 150 km/h? I have an 18 model T5 with 55,200 km on it.
4What's your RPM at 120 km/h?
5How can I remove the 120 km/h speed limit?
6Is there a 2007 Kia Sportage steering gear available?
7What could be causing the Roewe RX5 MAX 1.5T to start shaking when driving over 120 km/h?
8What is the RPM at 120 km/h?
9The car starts to shake after reaching 120 km/h on the highway.
10Loud noise at 100-120 km/h.
