I bought a second-hand Kia Sportage that's 10 years old. When going over bumps or speed bumps, the front chassis makes a creaking noise. I asked a repair shop, and they said it's likely the stabilizer bar bushings have aged. Replacing the two front stabilizer bar bushings would cost over 200, but they also mentioned that changing them might not necessarily solve the problem. Do you think it's necessary to replace them?
Help needed, the suspension of my V40 makes squeaky noises when getting in and out or going over speed bumps. I called for advice and they said it might be due to aging bushings. Has anyone else encountered this issue?
4Can the rubber bushings be replaced? The car makes a lot of noise when driving over bumpy roads.
5I bought a second-hand Kia Sportage that's 10 years old. When going over bumps or speed bumps, the front chassis makes a creaking noise. I asked a repair shop, and they said it's likely the stabilizer bar bushings have aged. Replacing the two front stabilizer bar bushings would cost over 200, but they also mentioned that changing them might not necessarily solve the problem. Do you think it's necessary to replace them?
6Is there any car owner experiencing a noise from the right rear wheel? When the temperature is low, there's a squeaking sound when going over speed bumps. There's no abnormality during normal driving, and it doesn't make noise on bumpy roads. The shock absorber isn't leaking either. The car is only three years old, so it shouldn't be the stabilizer bar bushing issue, plus the sound doesn't seem like it's from the stabilizer bar bushing.
7Do you guys experience a squeaking sound when the front wheels go over a speed bump or curb?
8Taurus chassis noise I have a 2019 Taurus, bought in 2021, and it's now at 57,000 kilometers. Recently, there's been a serious noise coming from the chassis, and it gets worse as the weather gets hotter. When the vehicle goes over speed bumps or when the front wheels hit uneven road surfaces at different times, there's a squeaky sound from underneath, like metal rotating inside a rubber bushing. When entering the garage and turning the steering wheel left, there's a clunk noise from the front when the front wheels hit a speed bump. The same clunk noise happens when parking with the steering wheel fully turned while reversing. The noise is very uncomfortable. Any suggestions from fellow car enthusiasts? Has anyone else experienced this?
9Does anyone with a V40 have a source for chassis bushings? I want to buy them myself and then find a repair shop to replace them.
10The repair shop suggested replacing the upper control arm bushing due to aging, but I found online that it might not be necessary. Any fellow car enthusiasts with experience who can help analyze this? The car has 84,000 kilometers on it currently.
