I bought a second-hand 2014 Kia Sportage, and the exhaust smells really bad. I hadn't driven it on the highway before, but a few days ago I did, and the engine warning light came on. The check indicated an issue with the oxygen sensor. After replacing it, the error code was cleared, but a few days later it came on again. It seems fine when not driving on the highway, but as soon as I do, the light comes on and stays on. Can any experts advise on how to fix this issue?
My car had a minor collision and was repaired, but the alignment wasn't done. The steering wheel is off-center. After driving for a while, an error code appeared, indicating that the stability control system needs repair. A diagnostic showed that the steering wheel position is incorrect. After clearing the error code, it came back after driving for a while. Can any experts advise on what the issue might be?
4I just got a 2011 Mazda 5 a couple of days ago. After only two days, the check engine light came on with the code P2177. Can anyone help explain this?
5I have a 2019 automatic RIO, changed the front and rear oxygen sensors, but after a few days the fault light comes back on! How did you guys solve this issue? What's your fuel consumption per 100 km? Mine is currently 10 liters per 100 km.
6The dashboard reported low transmission performance, and then the car wouldn't accelerate. After restarting, the warning light went off and it drove normally. What could be the reason? (The onboard computer cleared the fault light, but it came back on before I got home.)
7The transmission light on your car suddenly turned on for a few minutes and then went off. Sometimes it lights up while driving, but it hasn't come on in the past few days. What could be the reason?
8The car was fine when I parked it, but the next day when I started it, the engine fault yellow light came on. The car runs fine, but the yellow light stays on. It's been almost two years; does anyone know the reason? 😢
9I drove for about an hour at night, and the battery warning light came on. Then I stopped driving. The next day, when I drove again, the warning light was off. Can you tell me what's going on and if it's serious? Thanks.
10Hello everyone! I have a 2022 Pioneer Edition Toyota Asia Lion, and I recently installed ambient lights. A few days later, the car battery died. Does anyone have a good solution for this issue?
