How should I deal with my Kia Sportage burning oil after 120,000 km? Does it need a major repair? Has anyone else experienced this? Can you share your thoughts?
2013 Kia Sportage, 106,000 km, with four Hankook tires. There's a lot of tire noise when driving on the highway. Is there any way to fix this?
I have a 2015 Kia Sportage. The steering wheel starts to shake when I go over 120 km/h. What's going on? Can anyone help?
4Hey fellow car enthusiasts, how do you deal with the cup holder in the Kia Sportage? Cups tend to tip over easily since there's no limiter.
5The timing belt in a Kia Sportage engine typically needs to be replaced every 60,000 to 100,000 kilometers. However, it's always best to check the owner's manual or consult with a professional mechanic for the most accurate maintenance schedule for your specific vehicle model.
6Hey fellow car enthusiasts, my car seems to be burning oil. After about 7000 km on full synthetic oil, the dipstick shows it's almost at the minimum level 😭. This has happened in the last two maintenance sessions. It's a 2017 Jeep Compass with 120,000 km over 6 years. Has anyone else experienced engine oil burning, and how did you resolve or repair it?
7Is the third-generation 888 engine, with 70,000 kilometers on it, now burning one liter of oil every 5,000 kilometers? I've always used Castrol Edge 5W40 oil. Does it need a major overhaul?
8I've been driving a 2009 Kia Sportage manual GLS with 120,000 km on it. I've always used 5W-30 engine oil, but recently it seems to be burning oil a bit. Should I switch to 5W-40 oil for maintenance? Has anyone experienced this before and can share some insights?
92020 top model, currently at 120,000 km. Started burning oil shortly after changing the belt at 100,000 km! Anyone else experiencing the same issue? 🤦♂️
10If you're planning to replace the LED lights on a 2013 Kia Sportage yourself, you'll need to know the specific model of the LED lights required. It’s best to consult the vehicle's manual or check the existing LED bulbs for their specifications.
