Hey guys, why does the AC sometimes turn on by itself after starting the car? I usually don't forget to turn it off.
Hey guys, my car got hit by AC water droplets, can't scrape it off or wash it away. What can I use to remove it?
Hey folks, I need some advice. When I start the car and turn on the AC, there's this really bad smell at first, but it goes away after a bit. How can I fix this? Thanks!
4Even with power in the battery, my Jinxuan manual sometimes doesn't respond when starting. After turning it on and off a few times, it starts. Does anyone know what might be causing this?
5How long does the Jetur X90 turn off after starting the car with the one-click start on the phone?
6Does the ambient light in your Haval turn off by itself? In my car, every time I connect the Bluetooth music to my phone, I have to turn it on again when I start the car. It always turns off by itself.
7Hey guys, I have a 2022 3.0 Flagship version. How do I turn on the built-in dash cam? Does it turn on automatically when the car starts? Why isn't the light on the rearview mirror turning on after I start the car?
8Hey guys, I noticed something today with my Sharan. The compressor starts running as soon as I turn it on, but the fan doesn't spin! The fan only starts when I turn on the AC. Is yours the same way?
9Hi everyone, I need some advice. I have a 2016 Nissan X-Trail with 70,000 km on it. The AC blows cold air for about 10 minutes, but then the airflow decreases. If I turn off the AC for a while and then turn it back on, it works fine again, but after a few minutes, the airflow decreases once more. Alternatively, if I turn off the AC, the airflow increases, and when I turn the AC back on, it runs normally, but after about 10 minutes, the issue returns. What could be the problem? Thanks!
10I've had my car for over a year, and the auto start-stop has never worked. I went to the dealership, and after a test drive, the service staff said it works, but I need to turn off the AC for it to function. I've turned it off, but it still hasn't activated. How do you guys use it?
