Hey everyone, the AC isn't blowing any air, and there's no air coming out on internal circulation, only natural airflow. Have you encountered this before? Is it the blower that's broken? I saw online that there could be many reasons. Is it necessary to replace the blower with an original one?
The air conditioning internal circulation of the 2016 Hongqi H7 with the chrysanthemum logo is broken. How can it be repaired? Is it that one of the shafts of the air conditioning flap is broken? Do I have to replace the entire air conditioning assembly?
If the external circulation of your car's air conditioning system can't switch to internal circulation, it might be due to a problem with the actuator or a control switch. The cost for repair can vary depending on the make and model of the car and the specific issue. I recommend consulting a local mechanic for an accurate diagnosis and cost estimate.
4My 207's automatic air conditioning is having issues. The air only blows towards the windshield and can't be switched to other directions. The display on the panel works, but it doesn't actually change. The AC compressor starts, but it keeps blowing hot air. The temperature adjustment panel shows the settings, but the temperature doesn't change.
5I want to ask the experts, why does the air conditioning not work when I turn on the internal circulation? The light comes on briefly and then goes off, but the heating works fine. Why is that?
6The AC in my 2017 Peugeot 308 starts blowing hot air after a while, and the fan near the radiator isn't working. What's causing this problem? Does it require major repairs?
7When I turn on the AC in my 2019 Taurus, the rear vents blow hot air. What could be the reason for this? Can anyone help explain?
8Hey guys, the AC isn't cooling and is blowing hot air. When I turn on the AC, the compressor doesn't work, even though it's new. The repair shop said the fuse box has a bad connection and replacing it would cost over a thousand. What should I do?
9Hey everyone, the AC isn't blowing any air, and there's no air coming out on internal circulation, only natural airflow. Have you encountered this before? Is it the blower that's broken? I saw online that there could be many reasons. Is it necessary to replace the blower with an original one?
10Hi everyone, I need some advice. I have a 2016 Nissan X-Trail with 70,000 km on it. The AC blows cold air for about 10 minutes, but then the airflow decreases. If I turn off the AC for a while and then turn it back on, it works fine again, but after a few minutes, the airflow decreases once more. Alternatively, if I turn off the AC, the airflow increases, and when I turn the AC back on, it runs normally, but after about 10 minutes, the issue returns. What could be the problem? Thanks!
