حسين عوض
2023-07-19 10:54
Do you have any recommended links for high-quality car weather strips? The original seals aren't holding up well in the desert.
For a 12-year-old car that has already run 190,000 kilometers and is experiencing a lack of power when starting, it's generally recommended to use a high-mileage engine oil. High-mileage oils are specially formulated to help reduce oil consumption, minimize leaks and oil seepage, and reduce smoke and emissions in older engines. They also contain additives that help condition seals and protect worn engine parts. You might want to consider a 10W-40 or a 5W-30 high-mileage oil, depending on your climate and specific engine requirements. Always refer to your vehicle's manual or consult with a professional mechanic for the best advice tailored to your car's condition and needs.
I'm currently a college freshman and I really like the Toyota 86. I can save up to 20,000 per year. I want to know if the maintenance cost for the Toyota 86 is high. If I were to buy a used 86, which year would you recommend?
Has anyone driven the Xpeng on a plateau? How does the power performance of this car hold up at high altitudes? Does it experience significant power loss?
Do you have a link for the window glass inner seal strip?
For the 2011 VW Touran with a manual transmission, it's generally recommended to use high-quality engine oil that meets the manufacturer's specifications. A popular choice is synthetic engine oil from brands like Castrol, Mobil 1, or Shell. Always ensure the oil meets the VW 502.00 specification for optimal performance.
I tried upgrading my Nissan Sunny's low-spec dashboard to a high-spec one, but it failed due to a loose connector. Now, I can't even reinstall the original low-spec dashboard because the wiring is all messed up. Can anyone provide the dashboard wiring information? What should I do? Help needed 😭😭😭
Looking to upgrade the headlights. The original ones really don't cut it for high beams. Any recommendations?
Is the 3.0T Hongqi HS7 industrial waste? Would you recommend getting it? If I hold it long-term, will I constantly be dealing with repairs? Could current owners share their experiences? The annual mileage is just over 10,000 kilometers, and as long as the fuel consumption isn't outrageously high, it's acceptable, considering how big and heavy the car is. Thanks for sharing.
Hey car enthusiasts, does anyone know what’s up with the Jietu 2024 Glory Pro's infotainment system not connecting? I plug in the USB and nothing happens. I'm using the original data cable that works fine when I connect my phone to a computer. But when I plug it into the car's USB port to connect to the infotainment system, there's no response at all. I've downloaded both E-Link Driving Assistant and Driving Companion apps on my phone, but neither works. Any ideas?
Kia Kia Sportage
Kia SportageAED 97,000 ~ 136,000Diesel & Gasoline
