Can a wheel alignment be done if the rear tires of a 2015 Sportage are wearing unevenly?
I've been using the 2017 MDX for over a year, and the front tires are wearing out unevenly. After rotating the rear tires to the front and doing an alignment, the newly replaced tires are again showing severe uneven wear. Have any other car owners experienced this situation? Looking for advice.
Can the Acura MDX have a four-wheel alignment done?
4I'm looking for advice on my 2016 Volkswagen Multivan 4WD that's experiencing severe tire wear. I've done a wheel alignment, but it hasn't resolved the issue. Any insights would be appreciated.
5Does the 2023 RAV4 still have rear tire wear issues?
6Is it necessary to do wheel alignment after picking up the car? I did some research and found that issues with the camber angle can lead to inner tire wear. Not sure if the new model has this problem?
7My Kodiaq's rear inner tires are wearing unevenly and noticeably. The repair shop says the lower arm needs to be replaced because it's not an adjustable one, so four-wheel alignment can't be done. Does anyone know if this is correct?
8My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
9Are there any fellow drivers experiencing severe rear tire wear? After 30,000 kilometers, the rear tire treads are down to the warning line...
10Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦♂️
