أحمد أسد
2024-06-06 07:59
After turning the key, it doesn't spring back, and there is a squeaking sound when shifting gears. What could be the issue?
عبدالله عامر
عبدالله عامر2024-06-14 08:14
The key doesn't spring back, which might be an issue with the electric lock. You can take it apart to clean or replace it! If there's noise when shifting gears, check the clutch set. Once replaced, it will be smooth and as good as new.
When you press and hold the AC button on the Arrizo 3, the compressor works and cool air comes out. However, once you release the button, it automatically springs back and the button light doesn't turn on. What could be the issue?
My MG GT experiences jerky acceleration, and there's a squeaking sound when I turn the steering while driving. Additionally, there's a squeaking noise when I rev the engine after parking. What could be the issue?
What could be the reason for a Haima S5, 2016 model Enjoy Edition, not moving after shifting gears without accelerating?
What could be the issue if the fan doesn't turn on at 90°C for a 2016 manual XINRUI?
Gear shifting issue: When the car is cold and I switch from reverse to drive, it rolls back a bit after releasing the brake before moving forward. This doesn't happen when the car is warm. Anyone else experiencing this? It's a 2019 model with 80,000 kilometers on it.
What could be the reasons for not being able to shift gears?
What could cause a loud banging sound when I shift gears after the car has been parked overnight?
Nissan X-Trail e-Power, I have two questions: 1) When the door is opened in D or R gear, the car alarms, but it doesn't shift back to P gear. Is that correct? I seem to remember it would automatically shift back to P gear before. 2) The speed-sensitive setting for the front wipers is on, but it doesn't seem to activate automatically when it rains. Why? Thanks for the explanation.
Kia Kia Sportage
Kia SportageAED 97,000 ~ 136,000Diesel & Gasoline
