حسن لاويل
2024-07-07 01:07
When driving the Song Plus fuel vehicle at high speeds, subtly adjusting the steering feels like the steering wheel is sticky and requires some effort to push. It feels heavy, and I have to constantly correct it without any self-centering rebound force. What's going on?
حسين تركي
حسين تركي2024-07-29 02:35
It feels like I constantly have to adjust the steering wheel while driving on the highway.
نايف مبارك
نايف مبارك2024-07-07 09:43
The slightly heavy steering feel at high speeds is by design, to prevent losing control. If it goes beyond the norm, you might want to check the steering system.
حسن لاويل
حسن لاويل2024-07-07 09:35
It's not that kind of heavy; it's more like the steering wheel is getting stuck.
محمد فيصل
محمد فيصل2024-07-07 07:47
The faster the speed, the heavier the steering. At high speeds, it doesn't automatically center. Is it the same for all cars?
Does anyone feel that the steering of the Tucson tends to drift on the highway? I constantly need to make small adjustments. Is there no self-centering, or is there a setting for this? It's quite tiring to drive like this.
HS 30T 2WD, when driving on the highway, the steering feels sticky and doesn't return to the center, making it tiring to constantly adjust. This doesn't happen at low speeds or in hot weather. Has anyone else experienced this? How did you solve it? Some say it's an issue with the steering gear and needs a full replacement—is this true?
Hey guys, is your steering wheel heavy? Mine feels a bit heavy. How can I fix this?
I have a question for the owner of a BYD Song Plus fuel version. Does your car's steering wheel automatically return to the center after you turn it all the way while stationary and then start driving?
Does your Song Plus automatically realign the steering when you make small adjustments on the highway? Is there a lot of resistance when you adjust with one hand?
Hey fellow car enthusiasts! I'm driving the BYD Song Plus fuel version and I feel like the steering wheel isn't quite responsive. I've set it to Comfort mode, but it still feels a bit stiff while driving. Could it be that there's some feature I haven't turned off?
Hey folks, does the steering wheel of your BYD Song PLUS gasoline version feel heavy? Mine feels quite heavy when driving, and I'm not sure if this is just how the car is or if there's an issue with my steering system.
To the owners of the Song Plus Fuel version, I have a question. Does your steering wheel feel heavier compared to other brands? I feel like the steering wheel of this car is heavier than the other cars I've driven. What's going on? The after-sales service said that this car has semi-power steering. Is there really such a thing as semi-power steering?
Why is the steering on my 2018 X-Trail heavy and not returning to center automatically?
BYD BYD Song Plus
BYD Song PlusAED 118,900 ~ 143,900Hybrid
