Is the lack of power when going uphill and the rise in RPM without an increase in speed in your fuel-powered Song Plus due to a spark plug issue? It's only driven 19,000 kilometers.
Peugeot 206 automatic. Exhaust pipe leaking oil and emitting white smoke. The car can move on flat roads but the engine shakes. It lacks power going uphill. What's going on?
Hey car enthusiasts! For the 2017 MG GS 30T, if you're finding that the car lacks power when starting without using the accelerator, what could be the reason?
I've driven nearly 40,000 kilometers and I'm thinking about changing the spark plugs. Which model should I choose between Bosch and NGK? I saw a Bosch double platinum spark plug online. Is it necessary for this car to use double platinum?
4Is it lacking power, even struggling on uphill roads? Is this common or is there a specific reason?
5Is the MG car lacking power when going uphill? Does it jerk in second gear? Is this common?
6To the owners of the Song Plus Fuel version, I have a question. Does your steering wheel feel heavier compared to other brands? I feel like the steering wheel of this car is heavier than the other cars I've driven. What's going on? The after-sales service said that this car has semi-power steering. Is there really such a thing as semi-power steering?
7Yesterday, I went for maintenance and replaced the spark plug assembly. I want to ask, after a year and having driven 20,000 kilometers, is it necessary to replace it?
8Hey fellow car enthusiasts, my Song Plus flagship model suddenly lost power, but the battery check shows no issues. Has anyone experienced this before? How did you solve it? Thanks in advance for any advice!
9Is the lack of power when going uphill and the rise in RPM without an increase in speed in your fuel-powered Song Plus due to a spark plug issue? It's only driven 19,000 kilometers.
10If you left your car in D gear overnight and found it without power the next morning, it could be due to the battery being drained. Does anyone know why this happened?
