سعود جعفري
سعود جعفري
Nov 18
I have a question for fellow car enthusiasts: Does the active braking on the BYD Song Plus EV only work in Intelligent Pilot or Adaptive Cruise Control mode? I carefully tried manual driving while following closely, and even when I was about to hit something, there was no response (speed above 30). However, it works well in Intelligent Pilot or Adaptive Cruise modes. Is this normal?
أكبر عبد العزيز
أكبر عبد العزيز2024-11-22 21:05
Go to the store for a check-up.
عبدالرحمن صالح
عبدالرحمن صالح2024-11-21 23:18
The response is too sensitive when reversing, and it often brakes suddenly, giving me a scare.
محمد لحود
محمد لحود2024-11-20 18:02
It seems to be between 60 and 140.
عبدالرحمن عبد الناصر
عبدالرحمن عبد الناصر2024-11-19 11:11
The automatic braking is always active. I've experienced it two or three times already.
نايف مبارك
نايف مبارك2024-11-19 02:56
It seems like it reacts at around 50 km/h. I've had it trigger twice and it gave me quite a scare.
My 2002 Acr30's air conditioning has an issue. When I set the temperature above 18 degrees on either manual or automatic mode, it blows hot air, and there's an engine oil smell coming through. However, if I set it below 18 degrees, it blows cold air and the oil smell disappears. Has anyone else experienced this with their car, and how did you deal with it?
My 2019 Model 95, the USB port next to the cigarette lighter on the center console isn't working. It doesn't charge my phone, and when I plug in a USB drive, there's no response. What's going on?
What car control app is everyone using now? 🤔 My app stopped working! A few days ago, I tried to use it to turn on the air conditioning, but nothing happened. And today, I found that I can't even log in—no response at all. Is this car brand going bankrupt?
I've heard that the car's infotainment system is quite bad. Does it have a Sentry Mode? Carbon fiber repairs are so expensive, I really hope it can catch hit-and-runs.
2019 model (purchased in November 2019), two-wheel drive, five-seater luxury version. Recently, the push-start button isn't responsive, and I have to press it hard for it to work. What could be the issue? Could fellow car enthusiasts share some insights? Thanks.
Is your car key responsive? Sometimes I have to press mine several times before it works...
Hey fellow car enthusiasts! I'm driving the BYD Song Plus fuel version and I feel like the steering wheel isn't quite responsive. I've set it to Comfort mode, but it still feels a bit stiff while driving. Could it be that there's some feature I haven't turned off?
[Shocked] What's up with this car? Starting in S mode, I floored the pedal, the RPM hit 4000 and it was still in 2nd gear without shifting up automatically. It only shifted to 3rd gear after releasing the throttle for 3 seconds.
How well does the car's adaptive cruise control work in traffic jams? Is it practical? I'm only interested in its performance in traffic jam situations.
Hey car enthusiasts, does anyone know what’s up with the Jietu 2024 Glory Pro's infotainment system not connecting? I plug in the USB and nothing happens. I'm using the original data cable that works fine when I connect my phone to a computer. But when I plug it into the car's USB port to connect to the infotainment system, there's no response at all. I've downloaded both E-Link Driving Assistant and Driving Companion apps on my phone, but neither works. Any ideas?
BYD Song Plus
BYD Song PlusEGP 1,450,706 ~ 2,022,081Hybrid
