سلمان هلال
سلمان هلال
Jul 3
I feel like there's an issue with the Oil Plus's range. It showed a 300 range when parked, but dropped to 267 once I started driving.
حسن جابر
حسن جابر2024-08-02 22:31
The range is calculated based on the real-time fuel consumption of the last 50 kilometers. If you drove at 120 km/h, then at 100 km/h, you'll notice the range increases the more you drive. When I fill up the tank, it shows a maximum of 750, but mostly around 680.
عبدالرحمن جواد
عبدالرحمن جواد2024-07-29 11:34
It's normal. The computer calculates based on your last trip's fuel consumption pattern, and sometimes it might show more.
نايف مبارك
نايف مبارك2024-07-06 13:16
This phenomenon happens with all cars. The remaining range display can be different between when you turn off the engine and when you start it next time. It might be related to the temperature of the fuel in the tank.
عبد العزيز أسماء
عبد العزيز أسماء2024-07-03 22:13
Sometimes, the data from the last time you used the car only shows up the next time you start it.
I parked my Territory in the mall's underground parking. After paying the parking fee and stepping on the gas to go up, it suddenly couldn't move. The car started shaking like "tut tut tut," and it felt like something was stuck in the front. The engine seemed to lack power.
Is it just me, or does it feel like the prices in the used FJ market are dropping?
Sometimes I feel like the gear is stuck, especially when starting the car. Have you guys experienced this situation?
Just got the car 2 days ago. When I picked it up, it showed 435, but it seems like I've only driven less than 300, with a bit over 90 left, so I went to charge it. Is this normal for city driving?
When starting a cold car, the idle speed takes 5-6 minutes to drop below 1000 RPM, and the engine vibrates. I thought the throttle was dirty, cleaned it, but it didn't help. The oxygen sensor current shows -0.01 mA. The repair shop says it's fine, but I feel like there's an issue. What could be causing this?
Hey car enthusiasts, have you noticed this? When you're reversing into a parking spot, the car looks straight, but on the 360 camera, it appears skewed. Before, when I parked using the 360 camera, the image showed the car was straight, but once I got out, the front was actually tilted to the right. And when it seemed straight from the outside, the image showed it was slanted.
Hey everyone, what’s the fuel consumption of your Alto automatic? I feel mine is too high, 24.5 liters only covers about 300 km. The light came on at 287 km. Also, my idle speed when starting cold is around 1500, but it goes back to 1100 once the engine warms up. Is this normal for fuel consumption and idle speed?
Do you feel that the chassis of your Xiaoqi feels a bit loose when going over rough and hard surfaces, like uphill and downhill? Mine feels a bit loose, and it's only 20,000 kilometers in. I usually don't drive on rough roads, just once on a mountain road with stone slabs and once over a speed bump in the parking lot, and it didn't feel good.
Will the 2024 JETOUR X90 PLUS automatically release the electronic parking brake when the accelerator is pressed during start-up?
BYD Song Plus
BYD Song PlusTBDHybrid
