Hey guys, have you ever had your phone get super hot when left on the dashboard under the sun? Any tips on how to fix this?
I've had the top-end version of the Venucia Star for a year, and I've driven 4800 kilometers. Now I've noticed that when going over those really low speed bumps on highways, the rear end sways, with noticeable lateral movement at the back. (Speed is under 60, and ESP is automatically on.) Do you guys have the same issue?
Do you hear a sound like two wires colliding under the front left side of the dashboard when driving your Hyundai Reina on bumpy roads? It seems to be related to the steering gear. I've checked the chassis multiple times but couldn't find the issue. Have any of you experienced this problem?
I have a Maserati Quattroporte. Recently, when parked under the sun, the AC blows hot air, but after parking overnight in the garage, it works fine again. This keeps happening repeatedly. Does anyone know what might be the cause?
4Hey fellow car enthusiasts, has anyone experienced the 2022 model's metal plates making noise? The two short plates underneath also tend to misalign. Have you guys faced this issue and managed to fix it? Any tips would be appreciated [pray]
5Is it normal for the left side of the hood on the 2019 HS 2.0 Super Edition to be hot after parking? After about half an hour, it cools down and the whole hood is warm, but the temperature is acceptable.
6Hey guys, have you ever had your phone get super hot when left on the dashboard under the sun? Any tips on how to fix this?
7To check the fuse for the front left low beam on a Skoda, you should first refer to your vehicle's owner's manual. The manual typically contains a diagram showing the location of the fuse box and details about each fuse. In most Skoda models, the fuse box is usually located either under the dashboard on the driver's side or in the engine compartment. Once you locate the fuse box, look for the diagram that indicates which fuse corresponds to the low beam lights. Make sure to replace any blown fuse with one of the same amperage.
8Hey guys, how do you fix the issue where the dashboard lights stay on even after removing the key in a Suzuki SX4?
9What could be causing the wipers and headlights of my 2014 Peugeot 308 to activate automatically after locking the car? It's inconsistent and seems random, regardless of rainy or sunny weather. I recently took a trip, left the car under the sun, and when I returned, the wipers were upright, and the battery was completely drained. I just replaced the battery. It's really frustrating.
