Has your engine fuel line been replaced? Mine gave a warning today and needs to be replaced.
Is there a seatbelt warning light? Mine doesn't have one. Does yours?
Has your steering gear been replaced?
What's the fuel consumption for your 2.4 NA engine? Mine is around 14, is that normal? It feels a bit high.
4Has anyone experienced starting issues with their car? This problem has been going on for over a year. I've replaced the battery, cleaned the fuel lines, changed the spark plugs, and replaced the fuel pump, but still can't find the issue. The dealership is also at a loss. Every time I try to start the car, it takes three attempts to get it running. It feels like the fuel isn't reaching the engine when starting. I'm now afraid to drive, because if the engine stalls, it'll take three attempts to start it again. 😢😢😢 Does anyone know the reason?
5Does the timing chain of a 2013 MG3 need to be replaced? It's only been 100,000 kilometers. Has anyone changed it before?
6Has your engine fuel line been replaced? Mine gave a warning today and needs to be replaced.
7Fellow car enthusiasts, how often do you replace your solenoid valves? Mine needs replacing every year, and this year I've already replaced two.
8Has the T-Cross been recalled for a fuel pump replacement at the 4S shop? Have you noticed higher fuel consumption after the fuel pump was replaced?
9Has anyone replaced the high-pressure fuel pump and timing chain on a 1.6L engine?
10Did you get your brake pads and brake discs replaced at the 4S shop? How's the quality? I just got mine changed today for 2500 RMB.
