Has any owner of the Song PLUS DMi experienced the engine running for about 3 to 10 seconds upon startup and then shutting off, similar to a fuel car start? The dashboard shows HEV, and after a few seconds, the engine goes off and it normally displays EV. This issue started after a maintenance and vehicle controller version upgrade in September and has occurred 6 to 7 times in the past month without any pattern. This situation is different from the common issue of low-pressure fuel tank complaints or engine self-start after refueling. The 4S shop couldn't identify the problem and said they hadn't encountered this issue before, providing no definite answer. The technical manager speculated that it might be due to a problem with some cells in the power battery (low voltage), causing the engine to start for self-generation when the vehicle is started. The car has been used for over 2 years with a total mileage of 40,000 km, approximately 30,000 km on pure electric. Currently, the power battery shows some degradation, charging about 2.5 kWh less than normal, and sometimes the charge drops very quickly from 45% to 25%, with a 3% drop per kilometer instead of the usual 1% drop. However, the 4S shop said it hasn't reached the manufacturer's standard for free battery replacement. Model: 2021 Song Plus DMi 100KM Four-Wheel Drive Flagship PLUS.
After charging at a third-party station, my Tesla Model X went into self-protection mode and now it won't charge. What's the reason for this?
Is your Jetour X90 Manual Enjoyment 6-seater not showing the oil light on the dashboard during the self-check before starting the engine? Does it remain off even after starting the vehicle? Are you guys experiencing the same issue?
Is there anything other than a battery issue that could cause the auto start-stop to show the battery not fully charged on a three-year-old car?
4I feel like there's an issue with the Oil Plus's range. It showed a 300 range when parked, but dropped to 267 once I started driving.
5Why is the USB on my Song Plus Fuel Version not charging? Will I have to pay if I go to the 4S shop, considering it's still under warranty? If anyone knows, please let me know.
6Is there any oil consumption issue with the 2020 BYD Song PLUS fuel version?
7Does the Song PLUS gasoline version consume engine oil?
8Has any owner of the 3-motor version of the XP noticed a 4% drop in battery health after six months? I personally feel that I've taken good care of the battery, usually charging between 50% to 80% (slow charging), rarely using fast charging, and charging to 100% no more than five times. When not in use, I keep it plugged in and haven't driven aggressively or used the straight-line speed mode. Despite this, the battery health has still dropped by 4% in six months. Is anyone else experiencing the same thing?
9Did the price of the Honor edition drop after the launch of the new Song Plus?
10BYD Song Plus 2.0 Fuel version, the windshield washer fluid doesn't spray out, but after driving for a while, it starts working again. What could be the problem?
